Please Help!!!
Your problem description is kind of vague.
Thanks, Dave
Thanks, Dave
Do you have an FPSS?
Put a jumper wire in place of the start pill no your window switch and jumper the leads for the FPSS if you have it. Then test the WOT switch with the key in the run position not with the car running.
If this doesn't work eliminate the WOT switch and check again.
If the doesn't work recheck the wiring for your solenoids and so on.
Either that or try reversing whatever you did to 'fix' your bottle warmer.
