Dynotune Electronic Nitrous Activation switch - $65!!!!
Old Nov 10, 2004 | 08:02 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
Default Dynotune Electronic Nitrous Activation switch - $65!!!!
We are having a one week special on our Dynotune Electronic Nitrous Activation switch (TPS).
This Nitrous Activation switch simplfies the installation of your nitrous kit buy using an electronic device to turn the system on and off at wide open throttle.
The Fully potted electronics box is fully adjustable and has a bright indicator to make adjusments a snap! Simple mounting via the enclosure tabs.
http://www.dynotune.org/store/Script...?idproduct=105
Dean
Old Nov 10, 2004 | 09:41 PM
CAT3's Avatar
Restricted User
Dean, I assume it works with the LS1 TPS and does the instructions cover the LS1 TPS Setup?
How are adjustments made specifically?
Do you simply hold it at WOT, ign on, and turn a screw til the light comes on? or is more intensive then that?
Thanks.
Charlie
Old Nov 11, 2004 | 06:31 AM
LS1TECH Sponsor
Yes, works on LS1. Yes it has a simple screw/pot adjustment with LED. The adjustment procedure is exactly as you describe, WOT, adjust until it turns on. It is fully potted so you can mount it in the engine compartment as well. Very Nice unit
Cheers
Dan
Old Nov 11, 2004 | 06:46 PM
cyipher's Avatar
Alittle off subject, but will it work with a computer controled carb , off of a carbed third gen? , it dose have a tps sensor.
Cheers
Dan
Old Nov 12, 2004 | 11:59 AM
LS1TECH Sponsor
You just need to check and see if you get a 0-5V output from one of the tps wires
0= closed throttle
5v= Wide open throttle
Dan
Old Nov 12, 2004 | 06:31 PM
cyipher's Avatar
how far will the adjustment allow voltage to go, I.E. voltage range
0= closed throttle
Dan
Old Nov 13, 2004 | 01:22 PM
LS1TECH Sponsor
The voltage window is fully adjustable between 0 - 5 volts. You can set the voltage anywhere in that range that you want.
Dean
