Wiring 2 Stage Kit to Work with 6-Speed.
What I have in mind is using a first stage activated off a WOT microswitch. Then using a Digi-Set timer for the second stage with the timer being activated through the WOT microswitch that activates the first stage.
My problem is what happens when I lift ever so slightly begin shifts....the Digi-Set resets itself correct? So without having to run a push button or a high dollar N20 Controller like the NX Maximizer....how do I safely run a second stage of nitrous with a manual?
Thanks,
Dave
Thanks,
Dave
I know there is an easier why to do this, but it is too early and I am not seeing it this morning so I am just brainstorming and thinking outloud.
Thanks,
Dave
Set one up to spray at 3000 rpm..and the pther one halfway to your redline.....say 4700 rpm. Then both off 100 rpm before redline. When its setup this way and armed..you can grab any gear at any rpm and just mash the pedal. You will always be in the power.
