Need some opinions on DP
Old Nov 14, 2004 | 11:22 AM
Beast96Z's Avatar
Default Need some opinions on DP
I currently have a TNT F2 kit, brand new, never opened. I've decided now that I want to go direct port. I recently purchased a set of 4 TNT distribution blocks and 8 TNT fogger nozzles from a board member. My delima is, should I sell everything I have, and just go with a brand new kit, or should I try to piece the rest of this DP kit together? I'll have nitrous Dave do the plumbing. He's also been catching my eye with the NX kits. So out of these 3, which would be best:
1. Piece together the rest of the parts for the DP I have now?
2. Sell both kits I have now and buy a new TNT DP kit?
3. Sell both kits and buy a NX DP kit?
Old Nov 14, 2004 | 12:08 PM
hellbents10's Avatar
LS1Tech Sponsor
It depends on what noids you ahve and what feed line you have. All a direct port kit comes with is the better noids, nozzles, dist. blocks, and ss line for pluming. Sounds like you might have almost everything. How much hp are your noids good for though. Not too familier with TNT. If your f2 kit has the good noids just piece the rest together.
Old Nov 14, 2004 | 02:14 PM
Beast96Z's Avatar
There website says 350 rwhp, but my jet chart only goes to 250.
Old Nov 14, 2004 | 06:47 PM
LS1Tech Sponsor
Sounds like you just have to get jets and line. Its time to give nitro dave a call I think.
Old Nov 15, 2004 | 09:38 AM
Nitro Dave's Nitrous Outlet's Avatar
You have the most expensive parts.How much do you plan on spraying? What you have should be fine to plumb depending on what size shot you are looking to spray.
Dave
Old Nov 15, 2004 | 06:11 PM
Beast96Z's Avatar
Dave
I look to spray 250-300. This should fall within the capabilities of my solenoids I hope. I think the only things I'm needing now is some -3an fittings and some jets and a jet chart for EFI pressure. Dave, when is a good time to try and get ahold of you?
Old Nov 16, 2004 | 11:22 AM
I just sent you a very detailed pm.However you can call me anytime between 8:30 to 5:30.We are closed during lunch 12 to 1.
Give me a call.
Dave
Old Nov 16, 2004 | 06:20 PM
Beast96Z's Avatar
Give me a call.
Dave
Thanks, you answered all my questions.
