How can you build a standalone fuel system...
Old Nov 17, 2004 | 05:22 PM
Phil99vette's Avatar
7 Second Club
Default How can you build a standalone fuel system...
How can you build a standalone fuel system using the stock fuel tank? I know I have seen a few people do this...
Phil
Old Nov 17, 2004 | 05:45 PM
Beast96Z's Avatar
Just run lines to your stock tank instead of the 1 or 2 gallon fuel cell. You'd have to have some kinda sump and return, but I don't think it would be any diffrent than having a fuel cell up front. Just more line. It would be very easy with a metal tank, but a plastic tank would be a little more triky. You might have to think fo a minute on the plastic.
Old Nov 17, 2004 | 06:20 PM
LTLHOMER's Avatar
What he said. I did my own sorta sump setup by welding two -10 bulkhead fittings onto the tank and one goes to the nitrous fuel pump and the other to the motor fuel pump.
Old Nov 18, 2004 | 10:26 AM
Greg Fell's Avatar
A stand alone fuel system would allow you to run high octane gas. This is a major plus to me. Plus, I feel (probably in the minority) that its easier to tune a low pressure nitrous setup vs a high pressure.
I plan on doing something like this...
http://www.cofba.org/users/reckless/dp_fuel.html
Old Nov 18, 2004 | 10:58 AM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
In my opinion a stand alone fuel system is a very good way to go. They are not that expensive to do either. It will also allow you to run a higher octance gas in the nitrous cell. We can put together a stand alone system for right around $450 or so with everything you need to make it work, including tank, lines & fittings. Good luck with your project.
Thanks
Old Nov 18, 2004 | 01:45 PM
SDB's Avatar
SDB
Thanks
What kind of tank do you use for the stand alone fuel system? I am thinking about this down the road. I use stock lines and rails, with SVO30 lb injectors, Walboro intank, boost-a-pump (not used/not necessary). I use a can of TORCO ACCELERATOR with SUnoc 94 octane and have pulled 2 degree out for a 200 shot with no problems. Would like to hear/see more about your stand alone fuel system.
Old Nov 18, 2004 | 03:00 PM
marlowchris's Avatar
Thanks
Can you provide more details on your system? Also where in a C5 do you mount the fuel cell? Any pics would be great.
Old Nov 18, 2004 | 03:11 PM
johnny p's Avatar
Phil
I think Phil wants his Stock Gas Tank(s) Plumbed for a Stand Alone Fuel Sytem for his Nitrous setup Fellas instead of seperate Fuel Cells.
Old Nov 19, 2004 | 07:57 AM
7 Second Club
Exactly...
Old Nov 19, 2004 | 03:33 PM
EVIL's Avatar
is the c5 tanks plastic or metal?
i have seen the stock tank with a sump on a fbody with a metal tank.
tyson made a replacement tank for a f-body, maybe see if he can fab one up for ya.
Old Nov 19, 2004 | 08:52 PM
johnny p's Avatar
Plastic, Thanks for the info.
Old Jan 11, 2005 | 08:49 PM
383ss's Avatar
Thanks
pming you on that
Old Jan 11, 2005 | 09:29 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Just put a 8an tank bung in your tank at the bottom or lower side towards back you can get them from jeg or summit its a fitting with two nylon washers and a nut for the inside of tank. This is the way mine is done and i drilled a 6an at the top of the tank for the return line worked out nice.
Old Jan 11, 2005 | 10:12 PM
CAT3's Avatar
Restricted User
Ok, sorry Phil, maybe I am missing something but WTH would you want to run a piggyback fuel ssytem rather than a stand alone? Piggybacking off the stock tank will require you to use more race gas than traditional stand alone. I get the whole running a separate pump to keep from starving the rails and injectors, but just sounds like you could a helluva lot more with a stand alone.
Charlie
Old Jan 11, 2005 | 11:55 PM
DERTY's Avatar
The Bull
I put my writeup back online. http://www.derty.org/photogallery/da...directport.htm
Also, here are some more pictures.
http://www.derty.org/photogallery/ca....php?cat_id=19
Old Jan 12, 2005 | 07:58 AM
Noyzee's Avatar
8 second mod
I like my stand alone, but if you want the stock tank Tuff said it, just tap off the tank, and run a feed to a pump and regulator, and into the noids.
should be pretty simple. just have to drop the tank.
Old Jan 14, 2005 | 11:58 AM
GrannySShifting's Avatar
Did you buy 01-Z car or something?
