Wow TNT Rocks ... 6.44 @ 99.51
Originally Posted by WS6Power
68maro why do you say BS ?! Maybe you should trade that old brick in on a LS1 ! Carbs and trailers are a thing of the past. How do I post my time slip ? I don`t have a scanner but I do have a digital camera.
how do you post a time slip pic from a digital camera?
it seems wrong to me , my car 1.6's 60 fts and the best time ive got recorded was
60 ft .... 1.61
1/8 ..... 7.57 i think my mph was something like 92mph
(i'd have to look up the mph for sure)
1/4 ..... 11.98 @ 110mph
so my mph is way down from what it should be but it is an lt1 not ls1
my buddy run's constant low 1.5's 60 ft in his heads/cam dope (tnt) ls1 and 6.60-6.50's all day but at 107 mph , his car also weights w/ him in it 3660 ...
60 ft .... 1.61
Originally Posted by kumar75150
if u ran a 6.44 at 99mph, you are either retarded or the the track screwed up the timing or you let off at the end of the track
mike
Originally Posted by V6 Bird
Someone could have mopped his goofy ***...I do it all the time to folks. What was the reaction time on that pass? Anything unusual for you? LOL
mike
mike
Originally Posted by stangeater01
my friends ride did a 6.626 1/8 @ 107.10 10.28 with a 1.560 60' something is funny about thoes times!!!
looks bout right what do you see wrong with it?
5.90@119 with a 1.31 60ft tripping the 60ft marker with the rear tires. (1.27 60ft was the best with the front tires)
You should be around 107/110mph with that ET. Are you sure it wasn't a 7.44@99 because that sounds more like it. That is about what a 3500lb cam only car with alittle bottle and no suspension shoud run IMO.
Gpowie this is no BS. Time-slip pic can be seen at Drag Racing Results posted by Eric with NEXT. She spun 30` out and ran a 1.65 60` 5.99 @ 594` 6.44 1/8 ET. New times coming shortly with better track prep and weather.
Originally Posted by Asr_off
reaction time has nothing to do with your e/t time
Mike
The car should be in the low 4.xxx at the 330 ft marker. Much less running that time with a 1.65 60 foot. Ill throw the BS flag way up in the air for you buddy! Go blow smoke up someone elses ***
I dont know any track that measures at the 594 ft marker...Its 60ft, 330ft, and 660ft...IE 1/8 mile. You sure they didnt give you a motorcycle timeslip instead of yours....LOL Then the cycle would have let off at the end of the track or missed a gear and coasted.Mike
