Wow TNT Rocks ... 6.44 @ 99.51
Originally Posted by V6 Bird
The numbers arent adding up...Your track must have had something fly across and trip a finish line beam. Go run again and It will be a slower pass for sure.
The car should be in the low 4.xxx at the 330 ft marker. Much less running that time with a 1.65 60 foot. Ill throw the BS flag way up in the air for you buddy! Go blow smoke up someone elses ***
I dont know any track that measures at the 594 ft marker...Its 60ft, 330ft, and 660ft...IE 1/8 mile. You sure they didnt give you a motorcycle timeslip instead of yours....LOL Then the cycle would have let off at the end of the track or missed a gear and coasted.
Mike
I dont know any track that measures at the 594 ft marker...Its 60ft, 330ft, and 660ft...IE 1/8 mile. You sure they didnt give you a motorcycle timeslip instead of yours....LOL Then the cycle would have let off at the end of the track or missed a gear and coasted.Mike
I totally agree with you Mike.
A few tracks here measure 594 .. so if you lift or get on the brakes (Bracket Racing) you have the 594 time to judge ..
Answer to question:
https://ls1tech.com/forums/showthrea...8&page=3&pp=20
Answer to question:
