Anyone spraying through shifts on an auto?
Will it kill my tranny to run the 1/4 spraying all the way, even through shifts?
My car is a 2000 A4 Corvette with tranny built up good to 500RWHP but do not want to snap a drive shaft or mess the trans up just to get good times.
Cajun
You might want to try to use the search. Maybe even glance over the first few pages in this forum. The same question was asked a few days ago and is still on the first page.
Cajun
Cajun
I've always agreed with that philosophy as well. But then again, I have a built tranny.
Cajun
I also see you're an 08'er, what part? I'm over around Manor and China Grade Loop.
I had a 180 shot, um lol thats kinda freaky but i live On China Grade near Manor.
When I had a 4L60E, I sprayed 150 through a built one for over a year. I was running 6.2's/6.3's in the 1/8 mile with it.
What I am saying is "If you spray through shifts, the transmission will not survive for as long as it would without spraying through shifts. If you add for pressure for the 3/4 clutch apply you will eventually take out the pump. Either one of them can go at any time."
I have gone through every transmission you can think of and I know alot about all of them. You will go faster if you spray through the shifts though. My vote is to go ahead and do it but be prepared to repair the tranny.
My stock A4 lasted over a year with nitrous, out of the hole. Over 600+ passes too. It did lose 3-4 but look how much it took!
180shot, you must be running the nxl, and last time i checked, a wet 150 kit pulled harder out of the hole and all the way thru than the nxl 180....thats why i sold mine!
what am I missing?
I know a lot.
MSD uses pills
Malory uses a dial
You set it at what rpm you want it to come on at and where you want it to shut off at. Most people set the shutoff rpm 100rpms shy of the shift point that way it the nitrous won't be on for the shift.
Does that help you out?
MSD uses pills
Malory uses a dial
Fred, there are lots of people that believe you shouldn't spray through shifts in fear of damaging their tranny, and there are others like me who don't care.
