washer fluid can it be used for fuel?
Old Dec 3, 2004 | 01:45 PM
Z284U2TRY's Avatar
Default washer fluid can it be used for fuel?
Well been thinking of going direct port and just wondering if anyone has used the washer resevoir as a fuel cell? I see were there could be a hazard for front end collisions but anyone see anything wrong with using this?
Old Dec 3, 2004 | 02:50 PM
Poik's Avatar
You just gave me an awesome idea for a purge system.. But I can't help you out with the fuel part.
Old Dec 3, 2004 | 02:52 PM
LoPeY's Avatar
I would probably use something a bit more solid as a fuel cell. I've seen a fair share of cars after front end collisions and half the time there is washer fluid scattered all over the ground. The washer fluid reservoir is designed for something inert like washer fluid. Maybe you could fabricate a stronger container to put in place of the reservoir to use as a fuel cell. Just my $0.02.
Old Dec 3, 2004 | 02:56 PM
LastYearZ28's Avatar
Not worth you life over a couple hundred bucks to do it right man. Be safe.
Old Dec 5, 2004 | 09:36 AM
jcarroll845's Avatar
I agree!
Old Dec 5, 2004 | 11:09 AM
Magic Chicken's Avatar
12 Second Truck Club
Title of this post is really deceiving.
Old Dec 7, 2004 | 03:44 AM
BottleRocket's Avatar
best way i've seen it done is using a battery relocation and putting a fuel cell where it used to be
Old Dec 7, 2004 | 11:56 PM
GueSS Who's Avatar
I think over time it might eat a hole in that container also. I know if you leave gas in a 20oz bottle for a long period of time it will melt it. I would do like the above post say. Put it where the battery is.
Old Dec 9, 2004 | 06:38 AM
best way to go. and when you fill it, put 110 or something in it so you get a slight octane boost when you spray
Old Dec 9, 2004 | 06:41 AM
Assassin's Avatar
post title = ? flamable washer flud?............ oh yeah dont do that...
Old Dec 9, 2004 | 10:38 AM
DopeFedZ's Avatar
you can get a fuel cell from jegs for about $100.00. I wouldn't recommend you use the washer fluid resevoir.
