nitrous/a/f ratio wirring
Old Dec 12, 2004 | 02:42 PM
Tiger2o69's Avatar
Default nitrous/a/f ratio wirring
Ok getting ready to wire up several things here. Nitrous, cutou, a/f ratio, trans temp, maybe a few other things.
I dont know much about wiring things up and dont want to tap into something i dont need to. What wire do I use inside the car for these things?
Can I hook them all up to the same wire.
Old Dec 12, 2004 | 07:28 PM
Tiger2o69's Avatar
come one guys is there a pic of what wire to splice under the dash?
Old Dec 13, 2004 | 10:51 AM
Tiger2o69's Avatar
ttt.....
Old Jan 3, 2005 | 11:36 PM
Somebody09's Avatar
Go near the cigarette lighter in the console... there should be a pink wire going to your Traction Control button, connector if you don't have a button. Let that be the positive going to the cutout switch. The grey wire going to the Traction Control is the positive for dash/console lighting. You can wire all your grounds together and tap into either the black wire with white stripe, or the black wire from the cigarette lighter. You may want to use a fuse somewhere along the line.
Air/Fuel... LS1Speed.com (Gauges & Accessories section) sells an adapter for a clean setup. For the power and ground, you can use the pink, black, and gray wires.
The other gauge I did not buy because I have no idea what good that information will do me...
-somebody
