keyed/ignition source
Old Dec 13, 2004 | 12:06 AM
Deckhand's Avatar
Default keyed/ignition source
I am going to install a bottle warmer soon, and I would like to tap off a fuse that is only activated when the key/ignition is on for my switch.
Any suggestions?
thanks.
Old Dec 13, 2004 | 07:11 AM
DERTY's Avatar
The Bull
Tap into a wire off the back of the radio harness. There is a keyed wire in there, I believe it is pink. Just key up the car and use a voltmeter to find it. Pretty easy.
Run that to your switch and then to a relay. Use a power wire from the battery (not a fused source) to the relay and then to the bottle warmer. It will draw more current then the fused ignition sources will allow.
Old Dec 13, 2004 | 07:17 AM
badjuju342's Avatar
Deranged Rat Fink
If it's a GM , pink wire on your ignition harness going to the switch in the steering column.
Old Dec 13, 2004 | 07:59 PM
'02SS's Avatar
underneath the steering wheel,behind the kick panel;,i used the big brown wire;on the top of the white block thats in there.
Old Dec 14, 2004 | 04:27 PM
69_YENKO's Avatar
Any suggestions?
thanks.
there is a keyed ignition acc. terminal on the fuse box thats what i used for mine. but the heater drew to many amps and it kept popin fuses so i ran a direct wire from the battire.
