Hp tuners as window switch?
Old Dec 15, 2004 | 09:51 AM
Tiger2o69's Avatar
Default Hp tuners as window switch?
Anyone doing this? I have the new interface and heard it could be used. How can this be done please?
Old Dec 15, 2004 | 11:18 PM
Magic Chicken's Avatar
12 Second Truck Club
Did you read the help file? It tells you how to configure the outputs.
Old Dec 16, 2004 | 10:14 AM
Tiger2o69's Avatar
Are you talking about this?
Output
Output signal is to ground.
You can create your own qualification used to command the output.
Each box in the grid represents an individual output on the interface. Use the above picture as a guide.
To add an output to the table display, select the box in the grid that corresponds to the output # you are using on your interface then right click and select insert.
The insert menu will display a list of Vehicle Parameters and Enhanced IO inputs, which you can select from to use for your qualification.
Output Configuration
[img]mk:@MSITStore:Hp%20tunerVCM%20Suite.chm::/scan_cfg_out.jpg[/img]
Output will be commanded to on when your qualification is true. Output will be disabled when qualification is false.
You have 5 qualifications to choose from:
  • < # >: Parameter is within range.
  • Greater Than: Parameter is greater than value.
  • Less Than: Parameter is less than value.
  • Equal: Parameter is equal to value.
  • Not Equal: Parameter is not equal to value.
Frames Required is the number of consecutive frames that must either pass or fail your qualification to force a change in your output state. It is highly recommended you set this value to 2 or higher. If you have this set to 1 and have a packet loss, that individual packet loss could cause the change of state for your output signal
Old Dec 16, 2004 | 10:23 AM
Yes, and the wiring is in the beginning of the help file under Connecting to the Vehicle. 2 outputs, one turns it one, the other turns it off. Only problem is, I'm not 100% sure if you can have something turn off, only on. So I guess we need some additional assistance for this question.
Old Dec 31, 2004 | 11:55 AM
Tiger2o69's Avatar
Anyone have any additional info on this??? Anyone using this?
Old Dec 31, 2004 | 04:13 PM
TripleBlackRamAirT/A's Avatar
yes, you can have it turn off too. It just powers a relay which could be wired to either power on or off a circuit. Just wire in series, NC contacts and NO contacts on to turn on and one to turn off.
Old Dec 31, 2004 | 05:17 PM
koolrayz's Avatar
Doesnt it bother anyone that the only time it will work is when your dragging your laptop around? Just buy a window switch and be done with it.
Old Dec 31, 2004 | 11:54 PM
Tiger2o69's Avatar
I plan to buy a window switch but for for I want a quick fix......but not because of taking my laptop but i like to monitor my runs anyway.....Im getting the switch becuase I dont want to have to worry about hooking it up all the time.
Old Jan 1, 2005 | 01:13 AM
transam02's Avatar
How far did you get on the installation after I left?
Old Jan 1, 2005 | 01:24 AM
2MuchRiceMakesMeSick's Avatar
This is exactly what I was thinking.
Old Jan 1, 2005 | 10:58 AM
Tiger2o69's Avatar
Not too far. I ran the main nitrous line tru the firewall and put everything back together...
