Ok i'm doin standalone
Old Dec 30, 2004 | 03:33 PM
blacktransam's Avatar
Default Ok i'm doin standalone
alright i've decided on a standalone fuel system for the spray.. itll be filled with vp's no2 fuel at all times.. heres my question High or low pressure?? i searched and got conflicting answers.. only people with expierience in this please it would be much appreciated.. why do they say low pressure is easier to tune?? what makes it that way?? just kinda confused on that point
Old Dec 30, 2004 | 04:31 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Ok single nozzle or direct port? The main benifit of low pressure is your jetting options, or between size jetting. With a standalone high or low pressure you can make adjustments to your regulator for richer or leaner. On low pressure to change your tune make a small psi change. On high pressure you must make a larger psi change to see the same effect.
Ricky
Old Dec 30, 2004 | 05:55 PM
MUSTANGEATER's Avatar
Ricky
Ricky do you happen to have the Jets for a NX Single Nosle kit with a Lower Pressure Stand alone?
Floyd.
Old Dec 30, 2004 | 08:09 PM
probably single nozzle for the time being.. well one nozzle per stage..
Old Dec 30, 2004 | 08:14 PM
NXRICKY's Avatar
Yes I have some hp settings for low psi on a single nozzle. But if you are just using a single nozzle why not just stay at high pressure and keep the standard patterns? I can give you any jetting you need for our kits. I will need to know which pump/reg and how you are planning on setting up the fuel system.
Ricky
Floyd.
Old Dec 31, 2004 | 10:13 AM
Toecutter's Avatar
Ricky
I knew it. I knew you couldn' use the same EFI (high psi) jetting for a low psi system, just had never seen anyone confirm it. Thanks alot Ricky. I may be hitting you up soon for a low psi system for my bird. You're being here really makes a difference.
I visit another forum where Butch hangs out and it makes for some very interesting nitrous conversations.
Old Jan 1, 2005 | 10:52 AM
Ricky
well i'm really thinking low pressure do to the ease of building the standalone unit.. probably use like i holly red pump and a holley regulator as i have them both already.. gunna build a cell that sits where the battery used to be (probably about 1.2/2 gallons and make it a return style system)
would i be better off return less?? this is all new to me so i'm guessing here
Old Jan 1, 2005 | 02:59 PM
Toecutter's Avatar
Holley Red pump runs at 5.5 psi preset from the factory. It does not require a regulator.
Old Jan 1, 2005 | 03:24 PM
DERTY's Avatar
The Bull
If you are going to run a low pressure setup, get more pump then you need. A Holley black will support the 9 to 10 PSI that a NX kit requires. I personally preferred running my fuel cell with a return/bleed off to the tank. A simple 1 gallon cell will let you get a lot of passes in. I'll put my writeup back on line tonight so you can see all the details of the install. It's very easy to do and tuning it is very easy.
Old Jan 1, 2005 | 07:14 PM
Ben R's Avatar
Just remember that if you have a fogger you need to have the kit flowed every time you go to the track. Without having the kit flowed you can run into some MAJOR problems.
Old Jan 1, 2005 | 07:28 PM
NXRICKY's Avatar
I agree with Dirty perfectly, the red is just not going to cut it.
Ricky
Old Jan 1, 2005 | 07:30 PM
ok then scrap that pump
thanks for the info guys this is some good info
Old Jan 1, 2005 | 10:21 PM
DERTY's Avatar
The Bull
Here's my writeup. I need to clean it up. But you can get the point pretty quickly.
http://www.derty.org/photogallery/da...directport.htm
Here are some more pictures.
http://www.derty.org/photogallery/ca....php?cat_id=19
Old Jan 1, 2005 | 11:53 PM
Ben R's Avatar
Lookin' good Derty.
Did you sell your car or what? Any plans for a new project?
Old Jan 2, 2005 | 06:35 AM
damn thanks derty.. this is definetly what i'm gunna do..
Old Jan 2, 2005 | 08:51 AM
DERTY's Avatar
The Bull
The car will be out this year. I just spent a lot of time helping Harlan out and as a result I didn't get any time to work on mine. It should be pretty cool when it's all done. More details will come later on.
Old Jan 2, 2005 | 09:11 PM
please keep me posted.. my car should be coming to an end in a few weeks
Old Jan 2, 2005 | 09:22 PM
DERTY's Avatar
The Bull
I already ran this setup. It works like a champ. I just didn't run it at all this year as I was too busy.
Old Jan 3, 2005 | 12:24 AM
beefcake's Avatar
here are my thoughts holley red pumps are ok up to 200 hp but not worth taking the risk. the holley blue pumps are junk!!! well the ones that are new the crome looking ones. the old blue style were really reliable but i have had 4 crome blue pumps fail on my carbed nova. i think a much higher quality pump should be run like a bg of manga fuel. i run a product engineering they are the best quality out there!!! remember no fuel = no engine
p.s. it is not very wise to not run a regulator on any fuel pump espically one that claims it was set from factory. fuel flow varys on my things such as current and heat.
Old Jan 3, 2005 | 08:18 AM
next's Avatar
Derty, awesome write up!!!
