need opinions
Old Jan 1, 2005 | 11:28 AM
68maro's Avatar
7 Second Club / STF Veteran
Default need opinions
over the winter i'm pulling my motor and i already have a buyer lined up but i don't know what i want to replace it with? i already have a 565 lined up that runs 5.0s in a 2400lb camaro on motor it's a pat musi motor that would probably run 5.50's or so in my 3500lb turd and 5 teens on the juice. i also have acess to a 555 nitrous motor that makes 1000hp on the motor but is set up for nitrous. the question is i don't know if i want to go to tall deck stuff because then i have to change alot or just build a standard bowtie block 496-505 about 14.5-15.1cr nitrous motor that'll make about 900 or so on the motor. and no matter what i build it'll be built to take at least a 700-800 hit because i'm a nitrous junkie. i mean i didn't flinch at 500 on my little 468. so i guess this whole thing is should i say screw it and go big or keep it right around 500ci and still run low 8's on spray. at least if i keep it under 500 i can run the ls1tech outlaw class right?
