NX MAF + Tuning
Thanks
Ricky
Thanks
If you look at a stock Fbody MAF sensor you can take it apart into three pieces.
Piece 1- Upper housing- all this does is bolt to the MAF sensor and the TB.
Piece 2- Lower housing- all this does is bolt to the MAF sensor and the bellows leading to the filter
Piece 3- MAF sensor
The NX MAF kit replaces pieces 1 and 2 and retains the stock MAF sensor so there are ZERO tuning issues as found with aftermarket MAF sensors.
