You guys with bottle warmers come in!!
Old Jan 7, 2005 | 11:28 AM
Smoker_98's Avatar
Default You guys with bottle warmers come in!!
Ok so its really frickin cold here and I just finished hooking up my DynoTune fully automatic warmer. It works . . . but takes a really long time to warm up to 900 like 45 min. How long do some of yours take, do I need to adjust it more? Thanks in advance . . .
Old Jan 7, 2005 | 11:46 AM
MeanWS6's Avatar
thats about right
I have a chart that someone made, I gotta dig it up . .
Old Jan 7, 2005 | 11:47 AM
Magic Chicken's Avatar
12 Second Truck Club
Mine works pretty good, takes a little while to get up to pressure, but that's just how bottle heaters are (from my experience). A NX bottle blanket might be good for you.
Old Jan 7, 2005 | 11:48 AM
MeanWS6's Avatar
http://www.dragstuff.com/techarticle...e-heaters.html
scroll to the bottom
get a jacket from NX
Old Jan 7, 2005 | 12:19 PM
tonyt123blue's Avatar
same here.I heat it up in the house first then put the heater on it.
Old Jan 7, 2005 | 12:42 PM
Smoker_98's Avatar
So, is there a way to maybe hook up another bottle warmer to the pressure switch? Since my bottles all hidden away it would be kind of a pain to take it in and out all the time. I have a 15lb bottle and it looks like another heater might be able to fit . . . That silly thing drained my yellow top in just a little over an hour!!!!
Old Jan 7, 2005 | 12:49 PM
ls15244's Avatar
yep same here it does take a while u would think it would heat up quicker but it doesn't really get that hot u can still touch the heating pad .....
Old Jan 7, 2005 | 01:02 PM
I have the NOS heating element connected to the DynoTune pressure switch. My heating element gets too hot to touch. You can try putting a second heating element on there, don't see why you couldn't hook it up to the pressure switch. The NX bottle blankets will help keep your bottle from getting so cold and will help retain heat (heat soak, like that article says).
Old Jan 7, 2005 | 07:34 PM
fredv's Avatar
I suggest a move south, the bottles heat up a lot faster when they start at 75°
Old Jan 7, 2005 | 09:41 PM
Turo's Avatar
i was thinking the same thing. mine doesn't take anywhere near 45 mins, but then again its hot as hell here
Old Jan 7, 2005 | 09:48 PM
95Mystic TA's Avatar
Not advised but I usually keep my bottle closed for a few minutes with the heater on and then open it up. Pressure builds pretty quickly even when it's 30 degrees out.
Old Jan 7, 2005 | 10:20 PM
With the pressure switch that he's using, it doesn't matter if it's open or closed. It shuts off at a user definable pressure setting.
Old Jan 7, 2005 | 10:53 PM
Tiger2o69's Avatar
Im using a dynotune heater and you cant touch it for long at all. Burt the **** out of me. Anyway it takes about 20 mins max at 50 degrees. Maybe I just got a good one.
