NX MAF kit dyno numbers
Old Jan 13, 2005 | 12:48 AM
oufan2929's Avatar
Originally Posted by Gold Z
Each stage has a seperate TPS switch and an arming switch. Anytime during a race I can choose to use just one stage or both stages by just flipping the switch on whichever stage I choose.
OK, that's what I figured. Beautiful! How is yours setup? wet/wet, dry/wet?...oh, nevermind, I went back and read
Old Jan 14, 2005 | 12:16 AM
Gold Z's Avatar
Here's a pic of my system
Old Jan 14, 2005 | 01:31 AM
SDB's Avatar
SDB
I see you have a Metco Valvecover Breather....did you have to do anything special to use this or just slap it on. I was using one and it seemed to affect the idle. Are you using -6 main feed nitrous line (I assume), and is the fuel line -6 as well? No problem with fuel presure drop getting the fuel from the rail? I hate the idea of going to a whole separate fuel system. What is your fuel system like? Thanks for the input
SDB
Old Jan 14, 2005 | 02:31 PM
Tim 98z's Avatar
Nice #'s John!! Good luck with it and keep having fun!!
Tim
Old Jan 14, 2005 | 09:40 PM
Gold Z's Avatar
My fuel system is stock except for a walbro intank pump. I used the main line and feed lines that came with the MAF kit. No problem with lean spikes. The Metco breather has been on the engine since it was built. The engine idles rough but it has a big *** cam in it. Since the engine uses almost no oil between changes the breather must be working for my setup.
Old Jan 14, 2005 | 09:44 PM
Gold Z's Avatar
Hey Tim! How are the twins? Barb and I just became grandparents last week. I"M TOO YOUNG!........I heard you got your new Z flying. I sure hope we can get together for awhile this summer.
Old Jan 15, 2005 | 02:04 AM
Tim 98z's Avatar
All is well here! (7 months old next week) Gongrats on the new addition!! I know your exited!! Tell them I wish them well!!
Ill give you a buzz sometime.
Old Jan 15, 2005 | 10:03 AM
Green Thunder's Avatar
Nice #'s...
Old Jan 15, 2005 | 10:19 AM
SDB's Avatar
SDB
I will try my Metco breather again and see if it works out. I have a stock fuel system with a Walboro intank as well...installed a boost-a-pump, but found out it was not needed. I am glad i took your advice a while back and got the NX GM MAF Kit, it works great!
