Fast 90mm intake + 90mm TB + modified TNT ring
7 Second Club
It took about 45 minutes of work to get the TNT ring to bolt up to the 90mm TB. I had to enlarge the TNT ring by ~ .125 and cut the o-ring down slightly.
That's nice that you can get it to fit, but aren't you still reducing the I.D. down back to a almost stock inlet? I know that was the problem with the HPE rings. They fit around the TB, but the inlet was no bigger than the inlet on the TNT ring, plus there was a large drop off where the inside met the TB.
Originally Posted by 1fstGM
Isn't there a power ring that is a direct fit for the 90mm set up?
Dave
