Which head gaskets for Nitrous?
Old Jan 10, 2005 | 05:14 PM
Gimp98TNT's Avatar
Default Which head gaskets for Nitrous?
Which would you guys recommend for my setup?
I will be shooting 200-300 on a stock bottom end, while the heads are off i will have them milled for flatness, I will also be using ARP head studs. The heads are 98' year castings
I still drive it on the street a little poblably 1-2K a year
Here's a few i have been looking at
Cometics
Flatout copper
stock GM graphite
TIA
Jim
Old Jan 10, 2005 | 05:18 PM
Race Car Driver's Avatar
11 & 7 Second Clubs
Cometic or FelPro.
Old Jan 10, 2005 | 06:08 PM
Ben R's Avatar
Any MLS style gasket will probably get the job done. Cometic and Fel-Pro both offer MLS style gaskets for these LS1 motors.
You can also O-Ring the block, put a reciever groove in the heads, and use a copper gasket.
Old Jan 10, 2005 | 06:36 PM
laz's Avatar
laz
Hey i think a cometic is a good choice but it will not work with 98 heads without leaking water because the slot on the deck on cylinders 3 and 6 if you weld the slot so there perfectly flat then your good .
Old Jan 10, 2005 | 06:43 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Im going with stockers after talking to sponsors.
Old Jan 10, 2005 | 06:49 PM
11 & 7 Second Clubs
stock is good.
Old Jan 10, 2005 | 09:24 PM
Green Thunder's Avatar
Not knocking the GM MLS gaskets as I have a had good luck with them. As far as Cometic they have recently changed theirs and I am going to give them a shot (ordered some today as a matter of fact) to go with the AFR 225's I will soon be bolting on.
I had problems previously with the old design but the new ones look very promising..
I will update as time goes on... Plan to put them to the test with 15lbs of boost and spray...
Old Jan 10, 2005 | 10:11 PM
Gimp98TNT's Avatar
cool, i'll go with the stock ones, they have held a 250 shot. So way change what works.
Old Jan 11, 2005 | 08:12 PM
GueSS Who's Avatar
Harlen went 8's with stock MLS GM gaskets. I run a cometic but the only reason is because of the bore size of 4.03 on my motor. Now you can get a LS2 head gasket or a new Z06 head gasket for the bigger bores though.
Old Jan 16, 2005 | 10:48 AM
FireHawk22's Avatar
i have the cometic heads gaskets and i am using 250 shot on thim and thay are nice
Old Jan 16, 2005 | 02:50 PM
DERTY's Avatar
The Bull
Factory MLS gaskets will work fine. They are made in a similar manner to a Cometic.
Old Jan 16, 2005 | 05:39 PM
redbandit98's Avatar
i tired the cometics on my 98 they leaked like no other..went to oreillys and got the stock felpro graphites and have worked fine with my n20..
