Purging! Where? And a "How to"
too many people care what their PURGE looks like when purging.. what do you care? If you really want to see something.. put the blue or red led lights in the purge as well.. that should get you some good brownie points with the ricers.
lol
I put a set in the nostils once. Pull you filter and lid off and mount either one or two lines to the radiator support right there.They will come out of the nostils. It looks pretty sick from the outside but the driver can't see it very good. That is what you want, is to see it. I mounted the solinoid and everything under the lid since there is so much room on a ram air. Put a bracked for the hard line to go through or when you hit the purge the line will go all over the place.
ws.6 here, tnt kit..comes right up the middle of the windshield wiper cowl. good luck though.
the line size doesn't matter but the noids should be mounted to the main NOS noid.
I ran mine out the "lower" nostrils so I didn't have to run up the hood or use flexible tubing. I just bent the stainless lines to come up through the bumper support (at least on the driver side, went across it for the pass side since I ran out of stainless line). My n2o and purge noids are by the hood latch, mounted them there just for this purpose.
Cheers,
Bad30th
Not sure who this is, but I downloaded it a while ago:
TA purging
I used aluminum tubing for the purge lines... 1/4ID I believe. They look a lot better than copper lines IMO.
