Jimmy Jams ?
Old Jan 19, 2005 | 08:02 AM
exstanger's Avatar
Default Jimmy Jams ?
Those of you who have the JJ switch panel. Is it suppose to just float around in the ashtray or is it suppose to pop in and stay. Mine doesn't fit tight but before I called him I figured I would check with you guys. Thanks for your help. It is in the car in sig.
Old Jan 19, 2005 | 08:26 AM
redbandit98's Avatar
i think they are supposed to pop in there..i had trouble with mine staying as well..i finally got it to set pretty good but it doesnt take much for it to come out if you push on it just a little it will spring out...i dont know...
Old Jan 19, 2005 | 12:26 PM
99Ws6TransAm's Avatar
mine didnt sit tight either as well.. It would get snug..but come loose after i pushed the buttons on and off a few times. What i did..was pushed it to the point where it sat nice and flush..so i could put the ashtray cover down..then i hotglued it from underneath. Seeing as how hot glue wont melt or ruin the plastic..and it comes off easily once you start peeling it away.. no problems yet.
Old Jan 19, 2005 | 12:36 PM
iamsickofitall's Avatar
mine fits nice and snug...after i cut out the plastic bracket that the ashtray light sits in, the upper right switch wires stopped causing the plate to pop out
Old Jan 19, 2005 | 06:52 PM
tonyt123blue's Avatar
hot glue gun sticks nice.
Old Jan 20, 2005 | 07:56 AM
TNTramair's Avatar
all i did was ground down one of the edges slightly and it stays in place...but before i did that it would pop up.
