Help me pick a tire for nitrous.
Old Jan 26, 2005 | 06:32 PM
mike#9's Avatar
I hear better things about Hoosier than I do MT. The MT ET drags obviously have a great reputation...but everybody that I talk to like the QTP's much better than the ET Streets. How do the QTP's match up against the MT drag radials?
Old Jan 26, 2005 | 08:39 PM
Elite_Hot_Rod's Avatar
Can't speak to the differences between an MT ET street and an MT drag radial but I can tell you you definitelt don't want to run a MT ET Drag on the street. If there is any moisture at all on the road surface you'll be all over the place not to mention they aren't DOT approved. I always had pretty good luck with the 26" MT ET Streets, I regularly cut 1.5 60's on a 150 shot. Now I run a 28" X 10.5" X 15" W and cut 1.3 60's.
