Missfire on Nitrous, Help me chase down the gremlin!
with new 02 sensors and a slightly different tune. Changed the plugs and wires just for the hell of it. Plugs are gapped at .038. I'm spraying a NOS 5177 kit with no jets. It gave me about 130/200 at the wheels. Well last Sat I took the car to the track and misfiring it ran a 11.73 at 124.5. Now the car runs absolutly perfect NA. No miss, no bucking, stuttering or any of the such and traps between 112-114 NA. The wires are brand new. They are all seated, all the plugs are tight and the AFR is fine NA and on spray. It's not the MAF. EFIlive and AutoTap show no problems. Tried spraying with only one of the 2 lines hooked up to the intake for a smaller shot, and same result. The only thing I can think of is a week coil, so I got 8 used coils off of an LS1 with 40K on it. Those should be fine. I will switch them out tommorow and see if the problem goes away. Does anyone else have any suggestions of what it might be. I don't think it's a vacume leak, sprayed a can of breakclean all over the engine bay with no effect on idle. No codes eather. Ideas guys, similar problems and fixes. Any help or input is gratly appriciated.
p.s fuel pressure is fairly steary at 58-55. Thought it might be my FPSS. Bypassed it same result. Tried MAF from other LS1 same result. Thought I might have too little timing on spray gave it more and again same result. Leaning the car out or richining it up has no effect.
Dave
Dave
Dan
I FIXED IT YEAHHHHHH!!!!!!!!
Pulled the injectors, pulled the rails, the intake and the valve covers to see if there was anything wrong. Just like I expected nothing was wrong. Put the car back together. Reseated the injectors to make sure it wasn't them and checked the o rings. Everything looked cool. Pulled the plugs yet again (so easy now with no EGR AC or Air) checked every one all looked great. No fauling no cracks all looked thesame and good. Put a new set of TR5s at .035 in there and miss is gone. I don't know what fixed it. I know for a fact that it wasn't the wires or seating cuz I made sure those things were on there like 10 times. Is it possible NGK made weak plugs. Is there such a thing. Shoot maybe it wasn't the plugs at all. I don't know. All i know it's fixed. Shure would be nice to know what fixed it though. Ohh well.
