DRY - WET Conversion
I can just compensate the fuel with the wet kit only when I activate it.
Please correct me if I`m wrong.
For this and If I`m not mistaking all I have to do is ad a Fuel selenoid, an extra 3 feet of hose for the fuel line, a Fogger and the right combination of jets right ?
Feedback please.
Basicly all you need is the fuel noid with fittings, -4AN line to go from the rail to the noid, another piece of line to go from the noid to the fogger (depending on the nozzle it should be -3AN, or you can get a -4AN to -3AN line), and the fogger with jets.
You should contact a couple of our nitrous sponsors, I think all of them sell complete conversion kits with everything you need. It would probrably be cheaper to do that than buy everything serperate.
Thanks for the Info.
Part Number: NX-TPI
GENERAL MOTORS V-8 (50-75-100-150HP)
Price: $ 276.32
Convert your dry nitrous system, to a wet kit. kit includes solenoid, jets, lines, and fittings
I'm sure NitrousDave will post in here soon with input
Here's a on line NOS tech question type forum,
http://holley.iserviceassistant.com/...uestion=105721
This way you can run on NA tune and timing isn't pulled untill you hit the button and only for that duration.
And thanks guys for all the responses.
