What would happen if.....
Old Jan 21, 2005 | 02:06 PM
Wile_E's Avatar
Default What would happen if.....
.....say I was spraying in 1st or 2nd gear and I started to lose traction and let off the gas while in between the rpm range where my window switch was set. What would happen? Would it backfire?
This is on a wet kit btw.
Old Jan 21, 2005 | 02:12 PM
Poik's Avatar
Don't you have a WOT switch? If not, GET ONE!
Old Jan 21, 2005 | 02:13 PM
red90cobra's Avatar
if you have a full throttle switch it you should be alright. You should not let off the gas completely though. so it can suck up what's left after the solenoids shut off
Old Jan 21, 2005 | 02:19 PM
cyipher's Avatar
Well with a WOT switch your nitrous would shut off and nothing would happen, if you just had a window switch and a master arm, I dont know what would happen but its probally not going to be good.
Old Jan 21, 2005 | 03:33 PM
Blk98Z28's Avatar
Old Jan 21, 2005 | 04:06 PM
Wile_E's Avatar
I've got one.
Old Jan 21, 2005 | 04:07 PM
Wile_E's Avatar
I'll remember that.
Thanks for the replies guys.
