supercharge w/ nitrous?
Old Jan 23, 2005 | 03:23 PM
LS1BlackBeauty98's Avatar
Default supercharge w/ nitrous?
would u put nitrous (200 shot?) on a car that has already been supercharged?
this might sound sort of stupid, but its a question that is kinda confusing me.
also wouldn't that make the car insanely fast if that was the setup????
walk me through it guys...
Old Jan 23, 2005 | 03:28 PM
Race Car Driver's Avatar
11 & 7 Second Clubs
I ran my 2001 SS LS1 with Vortech SQ trim w/8 lbs boost, Venom 2000 - 100 dry shot, heads, cam, headers, A4, 3800 converter and gears, and it ran low 10s in Vegas with no problems. Wish I had it back in that condition.
Old Jan 23, 2005 | 03:45 PM
gator's 99TA's Avatar
that is a very large nitrous shot and will have negative implications on the tunnig - in terms of simplicity. sure it can be done, i am doing it. others have done it but 200, damn. why not just turn the boost harder or go to a bigger blower?
Old Jan 23, 2005 | 06:14 PM
860 Performance's Avatar
I run 15lbs of boost and two stages that ad up to a 300 shot. Tuning is pretty much straight forward. I like the set-up, it offers a ral nice daily driver that is fast without nitrous, then a killer with the bottle.
Old Jan 23, 2005 | 06:17 PM
ITSTOCK's Avatar
I run 16#'s of boost and will be spraying with a 175 shot, which will eventually be a a 200+ shot. Right now I'm only running an 125 shot.
gatorsta, there are a couple reasons. Blowers get maxed out obviously, hence why you probably said a bigger blower. That's not a problem, except it costs money and will eventually get maxed out also. It's much easier to just change jets .
Oh yea, I'm on stock bottom end
Old Jan 23, 2005 | 07:57 PM
i thought a 200 shot was a pretty big shot too
but obviously i dont know much bout nitrous n superchargers or i wouldnt have posted this topic
Old Jan 23, 2005 | 08:33 PM
smokeum99ta's Avatar
200 shot is big on a stock motor,hope your bottom end can handle all that boost/nitrious you plan on using!
Old Jan 23, 2005 | 08:42 PM
What I forgot to mention was I pushed my crank through all of the main caps last fall. What a mess... pieces shot through the oil pan, and I was at the track, so they had to shut down for a few and clean-up.
So, new motor with splayed billet caps is being built right now. Should be fun this year!
Old Jan 24, 2005 | 10:43 AM
GrannySShifting's Avatar
Cylinder pressure owns you
How fast are some of you guys going with boost and blowers? If you dont cam it right I can see it being a huge waste of time and eventually waste of motor.
Old Jan 24, 2005 | 10:54 AM
ITSTOCK's Avatar
stock cam for me, no times with the new clutch and spray, but a variety of low 11's at 121-123 off spray.
Oh yea, this is an LS1 sight. I believe dirtyZ has a blown/sprayed Z28, I wonder what cam he has?
Old Jan 24, 2005 | 11:00 AM
10.2 @ 134 with a 1.6 60ft so far. Its in is 3800 lb 79 Camaro with me in it. The cam I had in it at the time was pretty much a stock cam, only .480 lift.
Old Jan 24, 2005 | 11:16 AM
kcshaner's Avatar
Is it true that nitrous on top of FI actually has a bigger increase in performance due to the cooling effect?
I was planning on perhaps putting a 30 shot on my turbo'd car expecting maybe 40-50 hp and 50+ lbs of torque....but 200!
Old Jan 24, 2005 | 02:52 PM
NBM~01~WS6's Avatar
Those who are spraying on top of boost is your set-up a wet or dry shot??I have 8lbs of the stock bottom end and thinking about doing a small shot...
Old Jan 24, 2005 | 03:03 PM
11 & 7 Second Clubs
Yes, I sprayed a 100 dry shot through Venom 2000 unit, 8 lbs boost, LPE heads and stock bottom end. It ran great.
Old Jan 24, 2005 | 03:06 PM
ITSTOCK's Avatar
dry shot
Old Jan 24, 2005 | 04:35 PM
hondo's Avatar
yeah its basically in-cylinder intercooling
Old Jan 24, 2005 | 04:39 PM
Stage 1 200hp dry shot
Stage 2 100hp wet shot
