RPM Window Switches, Who makes the best?
I was planing on using a timing tuning with the delay on for the first stage and to lock out first gear then a window switch for the second stage. But if BNM is going to make a 2/3 stage switch I will have to look into getting one. How long til they get produced???
Robert56, will get it drawn up in a day or two for ya.
1BADAIR, could be 1 - 2 month's. We're finishing up our ad-on shiftlight and the window swith with delay built in. Also have to squeze in time for the progressive.
I have the MSD digital and it is really nice! Once you buy a few sets of pills and the normal one they are the same price. I bought mine for $80 brand new from some shop on eBay who had alot of them. It also acts a s a tach when its on which is kind of cool!
Originally Posted by 70Stang
Harlan.
Originally Posted by BMN
Robert56, take a gander at this. should do the trick for ya.
Yup, u get the ideal. The first stage is hooked up normaly. The second stage(higher turn on RPM) is hooked up as if it didn't have a WOT switch in line. Instead, the WOT switch works the relay that is in the spot the WOT switch would be for stage 2. WOT supplies ground to stage 1 relay and allows MSD to triger stage 2 relay ONLY after you shift into second.
