injector bungs or fogger nozzle
Im wanting to run a direct port set up.I cant decide if i should use fogger nozzles or the injector bungs. Can i get some pros and cons of both.
engine is a ls1 forged pistons. im looking to do a 150 shot with the direct port and a 75-100 shot dry, off the line.
8 second mod
i run the NOSzle kit, im very happy with it so far.
the injectors used realy need to have a strieght spray patter or there is a chance of pudling. the 42 svo have the patter so thats what i run.
its a lot easier then drilling the intake plubbing the nozzles ect. im happy with my chooce.
People have had success with both, but my personal preference would be tap the intake with nozzles.
Don't know your setup (drivetrain/suspension), but if you can hit the full shot outta the hole you'll pick up a ton of ET... not to mention the full out fun factor of a hard launch.
Originally Posted by Noyzee
I spray out of the hole. ESP went 8.9's with a NOSzle system 3 years ago.
That wasn't for YOU, Noyzee
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
camrsz was proposing hitting a small shot off the line and then a bigger shot down track.
8 second mod
ok, i took it wrong, i thought the way you said it was the noszle you couldnt hit out of the hole. my bad.
return road, comeon! i only did that once. lol
the hit out of the hole is unreal tho. love that, and i only hooked a 1.6 60' lol
8 second mod
the fat is going going almost gone. i should be down to 3300 this season i hope, maybe lighter. lol
1.3 60'!!
i need some time to work out my suspention but if i do that, i shoud knock 4 tenth off the top, then hit it harder
sorry.
do you mind maybe sending me a pm with your suspention set up/tire combo?
just wanted to compare. thanks
1.3 60'!!
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
![Offtopic](https://ls1tech.com/forums/images/smilies3/offtopic.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by Nitro Dave's Nitrous Outlet
Either way will work fine.Im a bigger fan of useing real nozzles and drilling the intake.
Dave
Dave
