ZEX kit
Anybody have the zex kit here, that would like to input on this.
You'll notice the 125 shot gained me about 13-14 mph on street tires. havent had it dynoed to tell exactly the hp numbers gain. As for the fuel scaling, i think it works for the most part, but at low bottle pressures the car still seems to run rich...
Very consistant, very easy to install.
Cant replace just solenoids to up the shot.
every kit has pros and cons.
Josh
The dry kit will adjust fuel pressure to the injectors by verying bottle pressure. You cut and split the vaccumm hose going to the regulator and plug the two halves on to the purple box.And since there is no adjustable regulator on most LS1 cars no adjusting via bottle pressure.
The dry kit would be shot in before the maf and the stock computer will do the tuning.
The wet kit I really do not believe it adjust for verying bottle pressure.I could be wrong though.
The wet kit injects after the maf.
Ricky
