Dynotune Bottle Warmer
Here is the section of our directions that show you how to adjust the bottle heater. It sounds as though the screw is turned totally counter clockwise. The switch adjusts from 500PSI to 1250PSI so it sounds like that may be the issue. If you still have an issue just let us know and we will do whatever we can to help you out.
Using and Adjusting the Warmer
1) You are ready to test your Bottle warmer! Follow all the directions and warnings for proper operation.
2) Make sure your blow down tube and Pressure Gauge are installed.
3) Open the nitrous bottle valve.
4) Verify the pressure at the bottle via the Gauge
5) Turn on the bottle warmer
6) Watch the pressure rise; it should go up to about 975 PSI then slowly cycle down to 925 PSI over time. If you notice the bottle heater never shuts off, or the pressure is much higher than 1000psi, shut off the Warmer and check all the wiring.
7) If you would like to make an adjustment to the pressure at which the bottle warmer will keep the bottle then adjust the screw that is located between the two terminals on the Nitrous Pressure Switch.
a. Clockwise increases bottle pressure
b. Counter Clockwise decreases bottle pressure.
Warning!! Do not turn the screw more than a ¼ turn at a time otherwise you may not know where the set point is. Always check your adjustments with your Nitrous Pressure Gauge.
Warning!! The valve on your bottle must be turned on for the bottle warmer to operate and control the Warmer. If the valve is left closed and the Warmer is on it will never shut off and the bottle tempeture/pressure will become extreme possibly resulting is the bottles over pressure safety disk bursting releasing the Nitrous out of the bottle. Nitrous will burn your skin! You must run a blow down tube that connects to the bottle Burst disk and vent the tube outside per NHRA rules to be a safe installation. You must use a pressure Gauge to verify and make adjustments to the Nitrous Pressure Switch. The Bottle Warmer may reach temperatures greater than 300 degrees f, be careful as this can burn your skin!
Dean
Just a reminder you can find the full instructions on our website if you misplaced your copy. Just click on the Instructions Button on the top left of our home page.
Dean
