Msd Window Switch On Ls1
Old Feb 9, 2005 | 06:30 PM
Mach1killerls1's Avatar
Default Msd Window Switch On Ls1
ok fellas i just ordered my msd window switch and just need a little back round info. such as what wire do i tap into the pcm in order to get a signal to the switch? wheres the best place to hide it. and does it come with wireing instructions for nos? and if not can someone please hook me up witht hem cause im so close to being done got the bottle in and noids just need to wire up..
Old Feb 9, 2005 | 07:47 PM
JoeyGC5's Avatar
Wll depends on if it's a digital or pillbox style switch. Both mainly use a power wire, ground wire, signal (to tach output from pcm), and a normally open and normally closed contact. There should be directions on the msd website. Do a search in the nitrous section and you'll find plenty of wiring schematics.
Old Feb 10, 2005 | 06:14 AM
30thz's Avatar
Wire it up like the direction say and do a search for the correct tach wire. We just did my buddy's 98 SS but i can't remember what wire on the PCM we used ( but i found it by doing a search).
yellow wire will hook up to the ground side of the FPSS.
grey not used.
If you are using the MSD Digital window switch in the setup it says for LS1's to set it to 1 Cylinder when we did this we didn't get the correct tach reading until we changed it to 4 Cylinder mode.
Old Feb 10, 2005 | 09:45 AM
TigerFan187's Avatar
Yeah if you get the digital WS you have to set it on 4 cylinder mode!
Old Feb 10, 2005 | 09:57 AM
Caribe's Avatar
I thought MSD fixed this problem with the Digital Window Switch? We are almost done intalling mine so I guess I'll find out.
Old Feb 10, 2005 | 05:29 PM
02 WS6 TA's Avatar
If I remember correctly, the tach lead is the pin # 10 on the lower connector.
On the 1998 models, the tach wire is in the upper connector, pin #35. Both will be a white wire. Hope that helps.
Old Feb 10, 2005 | 08:07 PM
redline2k's Avatar
I put mine in the glove box.
Old Feb 10, 2005 | 10:02 PM
thanks for the info guys it has been a real big help and i'll keep u guys up to date on whats going on. thanks again
