Yeah, irridiums come in heat ranges, just like the NGK's do. I got one step colder than stock.
Why wouldn't that be OK with nitrous? I wasn't showing any KR more than I was NA, either, according to my scan tool. And the irridium alloy they use for the tip is like 5 times stronger than platinum and melts at alot higher temperature, alot more resistant to oxidation, that allows them to make the tip so thin. A thin electrode = more concentrated spark = requires less voltage = ignites in a leaner environment than a standard plug would, so you should be able to run a wider gap and still light the mix. Or at least that's what I read in Denso's SAE paper. Nothing to do with heat. I always thought the heat range had to do with the size of the center post insulator, which would determine how fast the heat would travel from the center to the cylinder head. A longer insulator would retain the heat more, I thought, and might even glow red with a power adder like nitrous, providing enough latent heat to ignite the next air/fuel charge before the plug even fired (preignition).
