Testing TNT f1 w/ window switch
Old Feb 13, 2005 | 06:49 PM
sickss228's Avatar
Default Testing TNT f1 w/ window switch
I was trying to test my system today to make sure that my solenoids clicked when I depressed the WOT switch with the ignition and toggle switch in the on position (motor not running), well the solenoids didn't click and I'm wondering if it's because the window switch is in and the motor is not running above 3000 rpm am I right or do I have a wiring problem? Anyone know or have a similar problem? Thanks
Old Feb 13, 2005 | 06:54 PM
GM Muscle's Avatar
Yeah, it's because your window switch is set at 3,000rpm. Take out the "on" pill and replace it with a loop of wire stripped at both ends. Retry your test and you should be all set. Your not running a fuel pressure saftey switch, right?
Old Feb 13, 2005 | 07:33 PM
sickss228's Avatar
No I"m not running a FPSS. Thanks for the help I kinda figured I had to do something like that, although the instructions that come with the kit don't tell you how to test the system with the window switch, only the FPSS. Thanks again
Old Feb 13, 2005 | 07:47 PM
GM Muscle's Avatar
Not a problem. Let us know if it works alright.
Old Feb 14, 2005 | 05:05 PM
sickss228's Avatar
Hey man, just tried it and it worked now all I got to do is fill the bottle, thanks
Old Feb 14, 2005 | 05:47 PM
GM Muscle's Avatar
Good to hear. Get that bottle filled and go have some fun!
