Maf vs Direct Port
Old Feb 22, 2005 | 02:27 PM
Spenser309's Avatar
Default Maf vs Direct Port
which is safer? which one will do 200hp shot cheaper? Hell at the price that its cost me should i go with a turbo so i get some respect when i pull up to the meets.
Old Feb 22, 2005 | 11:35 PM
CAT3's Avatar
Restricted User
Most will agree a DP is the safest way to spray larger shots, although there are quite a few running the Single Nozzle wet, MAF etc with 200. The single nozzle can only atomize so much effectively, so twin nozzle or Dual MAF would be better than a single. Theres also the debate of puddling in the intake, or more so, the scariness of it which pushes many to go to a DP. I personally like the DPs but will be running 200 on a Twin Nozzle setup for a little while. A DP can be set up for less than $2500 with stand alone fuel system so no way in hell does the $ justify going FI.
Charlie
Old Feb 22, 2005 | 11:43 PM
Nitro Dave's Nitrous Outlet's Avatar
Actually.If you do not plan on going over a 200 I would do the single nozzle or maff kit.Directports are nice but alot off work and money.I have customers spraying 350 through single nozzle kits with no problem.
Dave
Old Feb 22, 2005 | 11:46 PM
VINCE's Avatar
Shorty Director
Dave
350 thru a single nozzle is a lot.
Old Feb 23, 2005 | 03:51 AM
Gold Z's Avatar
I prefer my NX MAF kit over my old NX DP setup for several reasons. One being that anytime I want to increase or decrease the shot I'm running, it only takes two jets instead of sixteen.
Old Feb 23, 2005 | 08:32 AM
Homeslice (tm)'s Avatar
Dave
Which nozzle are you using?
Old Feb 23, 2005 | 08:44 AM
got_hp?'s Avatar
Dave
hehe, thats a lot!
and i thought my friend was livin on the edge. he has a 355lt1 and is spraying 300 from one solenoid into two nozzles. races it every friday at the track, no probs. even crazier is he still has stock injectors, and is running 9.89.
Old Feb 23, 2005 | 08:48 AM
These guys race in classes that will not allow anything other than a single nozzle and two solenoids.
The nozzle is the SHO Nozzle.You are currect but if thats all you can use thats alll you can use. 200 or even 250 on the single nozzle is no biggie.
Dave
Old Feb 23, 2005 | 09:11 AM
white2001s10's Avatar
I have the bits to drill your nozzle out bigger if you want.
The single NOS#16000 solenoid will flow over 300hp pretty easily.
Your restriction is the nozzle.
