How much will a 4an
Old Feb 24, 2005 | 07:55 AM
Z284U2TRY's Avatar
Default How much will a 4an
main feed line support? Will it flow enough for a 300 direct port? What low psi fuel pump will support 300. Anyone know?
james
Old Feb 24, 2005 | 10:57 AM
Z284U2TRY's Avatar
seems from searching max crank hp is 250 for 4an main line?
Old Feb 24, 2005 | 11:33 AM
383LQ4SS's Avatar
well...if you cranked up the bottle pressure you might be able to get a littl more. I ran 1150 psi on a dry shot with a nitrogen push and was able to get approx 290 rwhp gain through a -4 line. But yeah...generally between 250-275
Old Feb 24, 2005 | 01:32 PM
Z284U2TRY's Avatar
I am guessing you have a indp fuel setup from reading your sig. What pump will support 6 psi of fuel on a 300 shot? Better yet what pump are you running?
