zz-409 cam vs. nitrous
I have 95 z28 w/ afr heads 190cc and zz-409 cam. Specs are 226/226 .554.554,112lsa w/ the 1.6 rockers. Is it ok that I'm running this cam with nitrous? I ran 150 shot and put 165 down. It is now jetted for a 200 shot. The only concern I've ever heard of is w/ single pattern cams, nitrous will begin to leak out of the exhaust valve with bigger shots of n20. Should I be concerned about anything else w/ this cam and a 200-250 shot?
I dont think you should have any problems with it as long as everything else is in place ...
Most nitrous cams favor the exhaust side to help clear the charge from the cylinder, but LSA and timing events are not as critical as they are on a blower cam or turbo cam unless you are spraying a huge shot.
Just my .02 ... I'm not a nitrous expert, but I did stay at a Holiday Inn Express last night ...
