new to n2o
Old Feb 24, 2005 | 11:52 PM
kjmdrumz3's Avatar
Default new to n2o
Just ordered the NOS 5177 kit. My question is: with my current setup plus a 125-shot, do I have to upgrade the fuel system? Getting a dynotune tomorrow, hopefully. Also, the kit comes with the bottle, brackets, lines, solenoids, jets, purge solenoid, lines, WOT switch. I would really like to get a window switch for safety reasons, a bottle warmer, and remote bottle opener. Speaking of the bottle opener, will this work?http://www.jegs.com/cgi-bin/ncommerc...81&prmenbr=361 Thanks in advance.
Old Feb 26, 2005 | 01:53 PM
Quick 99's Avatar
You shouldnt need a pump unless you are planning to spray 150 shot or more, you should be fine with your stock steup. A bottle heater and window switch are great ideas, the window switch especially because it will keep you from making any mistakes by accidentally activating the nitrous at the wrong rpm..
Old Feb 27, 2005 | 08:17 PM
ATVracr's Avatar
you may want to spray it on the Dyno first with an aftermarket MAF just to
make sure everything is OK.
