A4 spraying through shifts...
Bottom Line- I dont think its safe for parts, IMHO, it has to cause premature wear. But I spray from the line to the other end. I wasted the stock trans after 600+ passes, loads of nitrous, and ALWAYS Sprayed through the shifts.
Window switch is just good safety, not made entirely to turn off the nitrous for a shift. Used so you don't spray too low or too high (RPM's).
