Nitrous kick out idea
Old Mar 15, 2005 | 07:45 PM
jmac_98ls1's Avatar
Default Nitrous kick out idea
This may have been done already, but just a question. I have a new nitrous kit that i am installing and i powershift without lifting off the gas so a micro switch wouldnt work for me. Is there anyway that i can wire the micro switch at the TB and then tie into the clutch kit out switch, like what is use in the cruise control, and have it to when i bump the clutch during a shift it shuts the spray off and starts right back there. I consider myself a very good shifter and i dont miss gears, although the microswitch would be a back up in the case of a miss shift. Any idea's?
thanks alot
jmac
Old Mar 15, 2005 | 08:01 PM
nspr8td lt1's Avatar
RPM window switch. my mom always told me KISS, keep it simple stupid.
Old Mar 15, 2005 | 09:45 PM
Navy David SS's Avatar
I agree use the window switch as your shut off switch. For launch on nitrous use a 2-step (Harlan makes the only one that I know of). His 2-step has a built-in cut-off for the nitrous until the clutch pedal is released. Than the window switch takes over. Depends on your exact rmp shifts, you can vary your window and 2-step. I used the cruise control also when I was a M6. This system worked very well.
David
