Dry 100 shot, what else should i do to be safe
Old Mar 18, 2005 | 11:18 PM
z28convert's Avatar
Default Dry 100 shot, what else should i do to be safe
The mods I have done are in my signature. I have a dry 100 nos shot, i bought iridium plugs also. I heard I should upgrade the injectors and feul pump, Will I be ok for the time being? What else should i do before i hit it for the first time. And can anyone tell me just how much this shot will kick me in the ***?
Old Mar 19, 2005 | 08:00 AM
kendo347's Avatar
I would check the duty cycle of your injectors with the shot. If it exceeds 80 then yes change them. Your pump shoud be fine but you might as well upgrade to be on the safe side. Especially if you continue modding. I us to run a 150 dry shot on my stangs but it did not seem to hit nearly as hard as a 100 NX wet shot. I thing the nx kit is underated in power.
Old Mar 19, 2005 | 12:43 PM
z28convert's Avatar
i should want the duty cycle to be around 50% though right? Are there any specific brand of injectors I should look to get?
Old Mar 19, 2005 | 12:56 PM
ITSTOCK's Avatar
You can run 100+%, but they say 85% is the max you want to run an injector.
Old Mar 19, 2005 | 03:30 PM
00SilverWS6's Avatar
Have you guys ever tried upping the fuel pressure before replacing injectors?
Im from the DSM crowd and just getting into my f-body now, what we would do if we got around 90-95% duty cycle, we would up our fuel pressure from the 43.5 (2g) to 50 or so. That would solve it.
Old Mar 19, 2005 | 08:36 PM
Robert56's Avatar
The NOS dry 100hp hit is about 80rwhp. A lot of guys run stock plugs, timing fuel system, but I agree with above check your a/f to make sure. Iridium plugs?
Old Mar 19, 2005 | 10:37 PM
z28convert's Avatar
yeah, iridium spark plugs.
Old Mar 20, 2005 | 05:33 AM
DONAIMIAN's Avatar
LS1's are already at 58psi
Old Mar 20, 2005 | 05:45 AM
kendo347's Avatar
You should never run at 100% duty cycle. With that much current going through your injectors you could fry them. It's just like leaving your nos solenoids open with 30 amps running through it for too long. Toast!
Old Mar 20, 2005 | 05:59 AM
At idle? Either way, is it possible to bump it up about 5-10psi to bring injector duty down?
Old Mar 20, 2005 | 06:17 AM
DD966's Avatar
Maybe you already have them, but I'd invest in a window switch, FPSS, and purge, if I were you. And... those plugs are TR6's, right?
Old Mar 20, 2005 | 10:52 AM
z28convert's Avatar
tr6's, yes, and im new to nitrous so explain to me what a window switch is and FPSS.
Old Mar 20, 2005 | 11:42 AM
ITSTOCK's Avatar
It's a waste to spend money on a purge. I would NOT waste my money, well I didn't.
Old Mar 20, 2005 | 11:45 AM
ITSTOCK's Avatar
A window switch makes it so that the nitrous activates between certian RPMS. For your car, probably 3500 to 6100, so that it only sprays in between those RPMS. An FPSS is a fuel pressure safety switch, which connects to the fuel rails. If it senses a low pressure (not sure what it is on LS1's) than it will not allow the nitrous to activate.
I personally ahve never used one, neither has anyone I know. From what I remember, they were causing more problems that they were worth.
Old Mar 20, 2005 | 11:52 AM
Wyckedcamaro's Avatar
purge is good for when you are done with the nitrous and want to shut down the car at night..you should purge the lines so your noid(s) dont have constant pressure on them.
its a cheap insurance issue for you to bypass instead of sending NX your noid to have them rebuilt all the time
Old Mar 20, 2005 | 12:10 PM
ITSTOCK's Avatar
Or you just turn the bottle off and keep the nitrous on just to clear out the system. One works just as well as the next.
Old Mar 20, 2005 | 01:21 PM
DD966's Avatar
If you plan on using it at the track, you better give 'em a call and find out what safety pieces must accompany your system, or you'll get there and they won't let you run.
Secondly, IMO, there is no such thing as overkill (waste of money)when it comes to N2O safety equipment, especially if it's something you've never done before. Good Luck.
Old Mar 20, 2005 | 06:43 PM
z28convert's Avatar
i think the kit i bought has the fpss and i am looking into the purge prices. I want to take ever safety step just in case. thanks for the info.
Old Mar 20, 2005 | 06:45 PM
TRYTHSS's Avatar
yeah, definately safety is what you want in all of this stuff, i wouldnt call a purge a safety device, but i do recomend them. it is an easy way to release the pressure in the lines so you dont have constant pressure on them. i dont have a window switch but it is a good thing to have, and i think that every nitrous setup should have a FPSS....... that is just my opinion
