Suggestions on Nitrous Setup for 408
Old Mar 23, 2005 | 03:28 AM
BoneSS's Avatar
Default Suggestions on Nitrous Setup for 408
I am in the process of putting together a 408, pretty streetable, 93 octane at all times, visit the track every now and then, 12 bolt, auto car. What suggestions would you all have for the nitrous setup? I really haven't decided on how much I would like to spray. Probably 150 w/ the option of going up to 300 possibly? I want to utilize the Fast 90 intake, so I want that plumbed also from the very beginning. Thanks guys!
Old Mar 23, 2005 | 09:42 AM
Elite_Hot_Rod's Avatar
I liked the NX Gemini Twin MAF Kit I had on my 408. If you plan on running a shot larger than 150 you'll probably need a better fuel pump, injectors and you should run higher octane fuel.
Old Mar 23, 2005 | 12:06 PM
Z284U2TRY's Avatar
Direct port for 300 shot.
Old Mar 23, 2005 | 12:33 PM
02Z06man's Avatar
I second that vote
Old Mar 23, 2005 | 01:48 PM
BoneSS's Avatar
I doubt I would ever hardly use the 300 shot, but would like the possibility too...
Old Mar 23, 2005 | 03:51 PM
Z284U2TRY's Avatar
I am setting up to run a 300 but will most of the time be on a 200 and am going direct port with indp fuel cell.
Old Mar 23, 2005 | 04:40 PM
antz01ta's Avatar
10 Second Club + 14 Second Truck Club
why not go with a tnt f2 kit, that is my plan for my new n20 setup. then you can run it 2 stage for traction issues.
Old Mar 23, 2005 | 05:19 PM
Nitro Dave's Nitrous Outlet's Avatar
If you are in your mind probley never going to spray a 300 shot I would look into the NX maff kit or The TNT kit.The direct ports are nice mut require more maintnence,work and money.If you are seriously looking to spray a 300 go ahead and go direct port.I can put something custom together for you and plumb your intake.Let me know if I can help.
Thanks
Dave
Old Mar 23, 2005 | 09:17 PM
BoneSS's Avatar
I'm all about ease of use, less mainnence, and a little less money. I honestly doubt I would ever spray more than 150-200. Let me know Dave what you would have in mind in way of complete kits.
Old Mar 23, 2005 | 11:52 PM
I'd go with the NX Gemini Twin MAF kit if you don't intend on going over a 200 shot. You can set it up to run a single stage shot or dual staged if you want to go over 200, I had mine set up dual staged on a 300 shot. They are clean kits, fairly easy to install and make good power.
Old Mar 24, 2005 | 03:36 AM
BoneSS's Avatar
Sounds pretty good. What fuel system would I need to run it?
Old Mar 24, 2005 | 10:34 AM
If you are only going to run up to a 150 shot a Walbro 340(255LTR) intank pump should be fine.
Old Mar 24, 2005 | 05:32 PM
BoneSS's Avatar
How about injectors? Fuel rail?
Old Mar 24, 2005 | 07:08 PM
v8maro's Avatar
exactly what i am doing, TNT F4 kit
Old Mar 24, 2005 | 11:52 PM
The fuel rails will be fine. I assume your car is the 98 in your sig, they had 26.6Lb injectors which can handle a 150 shot but If you intend on going any higher you will want bigger injectors. I've got 40LB SVO injectors but I run a 300 shot and going bigger.
Old Mar 25, 2005 | 03:45 AM
BoneSS's Avatar
Thanks guys.
