Install pics; custom switch panel, DIY purge LEDs...
The switch panel is a custom piece that I made, which includes an LED that I wired into the ground of the main solenoids. Since I ran the ground through a WOT switch as a safety, the LED will illuminate when WOT is reached and therefore (assuming I have the arming and activation switches engaged) when the solenoids are active. I still have to mount the LEDs for the manual fan switch...thus the holes in the panel. The pics look kinda crappy becuase of the flash, but the panel is black in color and looks a lot nicer than it comes out in the pics.
As for the plate, I have a friend that's an engraver...I do the design work and he engraves it. We used to make all kinds of stuff and sell it, and we still do although not as frequently now. Say I was to manufacture these...from a market reseach standpoint, would you guys want a plate with swtiches already installed, or just a plate to mount them in yourself? Is everyone running switch setups similar to mine, or using the covered swithes or different setups and what are they controlling?
I think the most profitable panel, would be one that we could modify ourselfs, but one that would fit in place with NO drilling or glue. Like the factory panel that my traction control is on (only on Pontiacs). Make one that just snaps into place.
Nick, I used a 400 ohm resistor for each LED and wired the two together in parallel to the purge solenoid.
Greg, I've had a few people ask me about it so I'm going to make a how-to as soon as I get a chance to take some pics...I'll keep you posted. You should be able to use the same concept, just might have to mount the LEDs a little differently.
