Nx single nozzel kit owners?
Old Mar 31, 2005 | 12:55 AM
35thls1ss19's Avatar
Default Nx single nozzel kit owners?
Ok so i am goin to get the nx single nozzel kil. What bottle heater should i buy? What window switch do you suggest? Do i need a WOT switch with the window switch? And is this kit goin to be ok? My mods are in my sig maybe a cam heads in teh future..... i want to order all this before race season and its comin quick! So thanks in advance!
Old Mar 31, 2005 | 01:28 AM
Wicked_Hugger99's Avatar
Get the Gen X2 upgrade kit from NX. It comes w/ bottle heater, FPSS, blow down tube, etc. I believe the base kit should already have the WOT switch. I run an MSD window switch & would reccommend it esp w/ that 6sp because you dont want to spray at to low of an RPM nor spray through the shifting incase u miss a gear. Id set it at 3000rpm on and about 5800rpm off. Id also reccommend a 255 in-line or intank pump and at least some injectors from a 98 model ( the 28.8lbers) just to be safe but you dont have to. Id also get a nitrous pressure guage and a/f guage in a guage pod on ur A-pillar if i were you. Ur bottom end should handle up to a 150shot no prob but any more and id look into forged pieces. Im only using the 100shot myself on the stock bottom. Just my 2 pennies
Old Mar 31, 2005 | 01:48 PM
i was lookin at the bmn window switch. For a begginer what u think msd or bmn?
Old Mar 31, 2005 | 03:52 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
NX makes a good kit so you will be fine with that. Bottle Heater I would go with the Dynotune - $119.00. 300 watt for the Dynotune vs 240 Watt for the NX. In addition the Dynotune heater is adjustable.
I agree with Wicked_Hugger99 the MSD window switch works very well - I have heard good things about the BMN but have never personally used one.
Good luck!
Dean
Old Mar 31, 2005 | 07:01 PM
Magic Chicken's Avatar
12 Second Truck Club
Yes, Dynotune heater rocks. MSD digital window switch (if you can find one, they are usually on back order with the mail order companies), WOT switch definitely. If you went with the NX gex x2 kit, definitely still get the Dynotune pressure switch for the heater.
Old Mar 31, 2005 | 07:38 PM
is there a kit i can get the blow down tube, purge, pressure gauge, fuel preser switch but not the warmer so i can get the dyno tune? Also do i need all that stuff i just listed? thanks again
Old Mar 31, 2005 | 08:15 PM
LS1TECH Sponsor
We can supply you with our now infamous heater - $119 http://www.speedshop.org/store/scrip...p?idproduct=17
We can supply you with the Fuel Pressure Switch w/ Chrome fitting - $39.95 http://www.speedshop.org/store/scrip...?idproduct=135
We can supply you with the Purge - $69 http://www.speedshop.org/store/scrip...p?idproduct=24
The Blow Down Tube $29.00 is currently out of stock but should be in beginning of the week.
If you want a digital guage we can help you with that if you want an analog guage I know there are sponsors who carry them.
Good luck!
Dean
Old Apr 3, 2005 | 10:12 PM
-IH8RICE-'s Avatar
You dont need a digital window switch the regular ones work fine I bought mine off ebay and save a lot of money. And you also asked about a full throttle switch if you need one I would highly suggest it.
Old Apr 4, 2005 | 09:14 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
NX is offering a dual window switch with tps switch. Cleans up the install, and if you later in life want to do a progressive system just purchase the driver and your good to go.
Ricky
