Angry nitrous user
Jim C.
Good luck!
Bob
I tried the heater procedure you described, bikeboy1, but the vents shut off after I switch to floor or defrost. So if your theory is correct, it shouldn't be a vacuum leak.
http://www.ls1.com/forums/showthread...79#post5646779
Do you think this can be my problem? Same codes and same symptoms. I don't know much about the PCV valve, can someone please go into detail?
PS: I know this is a double post and I'm sorry, but I need to get attention to fix this problem and this Thread got lot's of attention before.
i agree with jimmyblue on the plastic intake or intake gaskets being blown out. once the car senses something is wrong it throws it into limp mode aka low timing table and it can be pretty damn slow, but what caused this to happen is what you need to know.
good deal man. now like stated above, try and figure out why that happened.
sounds like you know what's wrong?
