408 owners please chime in
Old Apr 2, 2005 | 08:56 AM
HIGH_INTREST's Avatar
Default 408 owners please chime in
I have a 408 going in my 99 FRC Corvette in six weeks and I'm trying to get an idea of what to expect.I will be running a TNT 200 shot w/MTI S1 cam .I have Kooks 1 7/8 headers hi-flow cats,LSX 90mm intake and LS2 TB.
PLease list:
Nitrous
Hp/Tq
6spd/Auto
yr/make
60ft
Et's and mph
I am currently running H/C w/150 shot and getting 10.80's @129mph.
Thanks for the help!!
Old Apr 2, 2005 | 09:56 AM
RED98WS6's Avatar
PLease list:
Nitrous
Hp/Tq
6spd/Auto
yr/make
60ft
Et's and mph
Jeez, w/ a stroker motor and 200 shot you should be able to get into the 9s provided your drivetrain and chassis can handle the power. Good luck.
Old Apr 2, 2005 | 11:19 AM
Elite_Hot_Rod's Avatar
NX Gemini Twin MAF kit dual staged 300 shot making 250 to the wheels
478RWHP/580RWTQ on motor, 723RWHP/ 666 RWTQ on the bottle
TH-400
99 T/A
1.32 60ft AVG
9.23@149.1
Old Apr 2, 2005 | 12:53 PM
Magic Chicken's Avatar
12 Second Truck Club
TH-400
99 T/A
1.32 60ft AVG
9.23@149.1
What are the specs on that motor? Those are some impressive numbers.
Old Apr 2, 2005 | 02:51 PM
tektrans's Avatar
My 408 with a 225 shot made 640 rwhp at the wheels thru a th350, 12 bolt, 3:42 gears and slicks. Depending on your cars weight i'd say 9.40's up to 9.70's depending on proper set up.
Old Apr 2, 2005 | 03:13 PM
6.0 ltr iron block bored .030 over
Calles 4" forged crank
Crower 6.125" forged rods
Diamond 4.030" forged pistons
CNC custom LQ9 high compression heads 2.055 intake/1.70 exhaust valves
Cometic head gaskets
LSX 90MM intake manifold and T/B
Mezeire Electric water pump
ARP fastners top to bottom, front to back.
The motor actually made more torque than the 666 I showed. We used an MPH graph instead of a RPM graph to smooth it out. When we pulled it we went from 75mph to 125mph in 1.25 seconds. This was thru the TH-400, Moser 12 bolt with 3:73s and on slicks.
Old Apr 3, 2005 | 10:45 PM
MeanWS6's Avatar
Dont mean to hijack the thread, but while we are on the subject, do ya think my PIG vert 408ci, TH400, 3.73 on 26" slicks will see 10's on motor and high nines on spray? (say a 200-250 shot)
Old Apr 3, 2005 | 11:09 PM
Never ran mine on in the 1/4 on motor but it ran a 6.80 in the 1/8th on motor. If you use a 1.57 conversition factor that would be a 10.67, my car weighs 3450 with me in it. The convertible probably weighs somewhere around 400LBS more than that so I would say low 11s on motor.
Old Apr 3, 2005 | 11:53 PM
NVR4GET's Avatar
What do you run in the 1/8 on nitrous?
Matt
Old Apr 4, 2005 | 06:01 AM
tektrans's Avatar
If you can hook with the 3:73's and 26 inch tires I'll think you'll see high 10's on motor.
I think you'll run out of gear with that gear/tire combo on the spray if you even hook at all.
My heavy Trans Am went 11.05 with 3:42's and 28 inch slicks. I'm gonna lighten it up a little to see 10's.
Old Apr 4, 2005 | 10:29 AM
Best 1/8th mile so far was a 5.90 but I've completely changed the set up now, hoping for 5.70s.
Matt
Old Apr 7, 2005 | 11:22 AM
Early May w/200 shot will be going in.I can't wait!!
Old Apr 7, 2005 | 11:58 AM
NOSjohn's Avatar
Restricted User
10.80's with H/C/spray is VERY respectable. The need for speed, it never dies.
Old Apr 7, 2005 | 02:06 PM
Thanks.Yea I'm already looking at turbos or blower and I haven't even got the motor in yet.
Old Apr 7, 2005 | 02:09 PM
Shoulder Shaker's Avatar
Damn I licking my chops because if I can get those kinds of numbers I going to be overjoyed.
Old Apr 7, 2005 | 02:34 PM
NOSjohn's Avatar
Restricted User
Did you sell the heads & cam from the other motor?
Old Apr 7, 2005 | 06:39 PM
I will be selling the Ls6 intake and MTI X-1 cam.I will be using my LS6 heads.If intrested I will get you a price.
I also have TPIS 1 3/4 headers w/Randon Tech x-pipe and hi-flow cats $850.
Old Apr 7, 2005 | 06:41 PM
Just make sure you go with a 90mm TB & intake.I've seen gains of 40-60rwhp with 90mm setup.
Old Apr 7, 2005 | 07:28 PM
40-60 rwhp by just adding a 90/90 setup?
Old Apr 7, 2005 | 07:35 PM
VINCE's Avatar
Shorty Director
Engine dyno #'s in the sig and I have been over 750rwhp and over 850rwtq on the spray. I have a dual stage setup. I am playing with it now because I only want 725rwhp/700rwtq. Traction is needed.
