Can i bump up my shot????
Old Apr 2, 2005 | 09:59 PM
Nasty Hawk's Avatar
Default Can i bump up my shot????
I am running a NOS 5177 Dry kit with a 125 shot now. I recently installed a Racetronix fuel system and a set of Ford red top 30# injectors. Do you think i could bump up the shot to say a 150???? All other mods are listed below, tell me what you think.. Thanks,,
Old Apr 2, 2005 | 10:25 PM
RED98WS6's Avatar
On a stock rotating assembly? I dont know. I'd say your pushing the limits....
Need forged rods and pistons...
Old Apr 2, 2005 | 11:05 PM
BriancWS6's Avatar
As far as the rotating assembly goes, your fine, the TNT wet systems put out ALOT more than a 5177 kit, and people run them all the time, just make sure your not going lean and you'll be fine. Good luck!!!!
Old Apr 2, 2005 | 11:14 PM
red90cobra's Avatar
spray open noid, I've done it
Old Apr 2, 2005 | 11:42 PM
Robert56's Avatar
Go for it, I have. If you want the real jet sizes for the 150rwhp, let me know. Dual .043's as NOS specs is 150hp at crank or 127.5rwhp using 15% drivetrain loss. Remember NOS over rates for safety.
Old Apr 3, 2005 | 04:19 PM
TRYTHSS's Avatar
they over rate for safety? i didnt know that, but i guess they know that there are some people out there that will try anything fist and then ask the questions.....
Old Apr 5, 2005 | 10:42 PM
Honez's Avatar
I would bet you will be lean on anything bigger than your currently running. I would switch it to a wet kit. Much safter and will hit like a ****. `
Old Apr 6, 2005 | 12:51 PM
tonyt123blue's Avatar
I am running a 224/224 on a 114 lsa with ported 5.3 heads I am running no jets in my 5177 with an AFR around 11.5 .I have a walbro 255 intank and 30 lb svo injectors.I have run about 7 bottles with no problems.
