TNT f4 kit, wiring q?
Old Apr 4, 2005 | 02:36 PM
v8maro's Avatar
Default TNT f4 kit, wiring q?
I got a TNT F4 kit, does anyone know where I can get a wiring diagram for this thing?
thanks
-Steve
Old Apr 4, 2005 | 03:11 PM
David@TNT's Avatar
thanks
-Steve
We dont have the F-4 on the web, but you can use this diagram and run 2 relays instead of the 1 ill..http://www.texasnitroustechnology.co...structions.pdf
Old Apr 5, 2005 | 07:40 AM
v8maro's Avatar
So with 2 relays would I just hook up each component up twice (IE 1 to each relay)? As in, WOT switch, FPSS, window switch, and then each selenoid is connected to a relay? sorry if i confused you.
thanks
-Steve
Old Apr 7, 2005 | 08:22 AM
v8maro's Avatar
Ok, I made a mockup of how to wire my TNT F4 kit. Please look at this and help me out. I believe I wired the yellow wire from the MSD window switch to the relays properly. I do not think I hooked up the FPSS to the yellow wire and to the solenoids properly, can someone help me out with this?
Also, when looking at the pic above, if you don't know what the symbols are, check out the .pdf file that was posted by the TNT guys a few days ago (2 posts above)
Thanks
-Steve
Old Apr 10, 2005 | 02:24 AM
v8maro's Avatar
t t t
Old Apr 11, 2005 | 09:43 AM
David@TNT's Avatar
Thanks
-Steve
Not a bad drawing, the only thing I would not want to do is the grounds for the solenoids going through the fpss, you would want it to break the ground on the on the window switch or the relays but not the ground 4 the sol..
Old Apr 11, 2005 | 09:45 AM
David@TNT's Avatar
thanks
-Steve
I think your on the right page, but 2 sol would be wired off the relay.. Are you still having problems??
Old Apr 11, 2005 | 10:21 AM
v8maro's Avatar
No, just pre-planning. I don't want to do much trial and error crapola, just want to have the wiring in my head/on paper set, goto the car, work on it, and be done. Could you maybe draw with MS Paint what you mean in your previous post?
Thanks for the help,
-Steve
Old Apr 11, 2005 | 10:23 AM
v8maro's Avatar
Ok, from reading this you are saying just ground the 'noids, and break the relays with the FPSS? I'll re-do the drawing and post back in a few....
-Steve
Old Apr 11, 2005 | 10:25 AM
v8maro's Avatar
So all 4 'noids would be on one relay?? I thought you said to run 2 relays?
i am confused now
lol
-Steve
Old Apr 11, 2005 | 10:33 AM
v8maro's Avatar
Ok, here is revision 2, grounded the noids on their own, and put the FPSS inline with the relays to break that yellow line if it fails.
LMK
thanks
-Steve
