Another DRY shot hits hard thread...(pic)
"I understand everything except how you can still spray in front of the MAF. How is that not adding fuel as well? I have ran this type of system on my other cars, but they are all MAP sensor cars, not MAF."
I'm curious to see what your A/F will look like with only the extra fueling from the added fuel pressure. How much have you played around with the vacuum T-jet? Can you make major changes in the added fuel pressure or just very minor ones? Also, where are you running the vacuum from? I had a problem in the past with leaning out the cylinder closest to the vacuum port. All the nitrous that was passing through the regulator line was building up on that one cylinder along with the existing shot and hitting it harder than the rest. So I had to set it up differently from the way the kits were designed to begin with.
Once I move the nozzle, i can measure EXACTLY what fuel pressure i want it to spike to by using a jet to bleed off vaccuum back into the intake. I get my vacuum from right behind the TB on the right side...But its not really even seeing any vaccuum but what passes back into the intake...The regulator sees the vaccuum from the nitrous discharge. Im wondering if you had yours setup wrong? The jet is what bleed of the pressure from the spiker and its supposed to go back into the line to your intake. I can regulate the pressure by changing shims in the spiker, and by using jets...I meant to clarify that a little bit.
Mike
Mike
MONEY
Can someone talk Jeff into letting me spray mine with the 250 shot.
MONEY
Once i get the tune squared away ill end up pilling it down...because the nitrous and fuel will be closer to what the pill numbers i was given....Its making 200 hp at the wheels now...With these pills most cars make 240 at the wheels...If i can keep the power curve flat so it doesnt drop off up top i should see some good mph too.
Its so weak because its pig *** rich. I was hoping for 109 or better honestly.
Mike
Mike
Mike
Jeff says it will never hook off the Tbrake on the jug
Depending on how your regualtor references boost depends on hwo much fuel pressure you will see...Mine is a 1:1 reference.for every 1 lb of vaccum I got 1 psi more of fp...Im spraying through the MAF which will soon change and ill be able to tune more effieciently with jetting and shims to get the amount of fuel that i want. Its really very precise if its setup right.
Mike
after we get Waynes done (hes on stock rails, feed line, returnless 99 setup)Can you jet it down so it only bumps the fuel pressure up a few psi, basically just a tiny bit of enrichment, or is it always putting a decent amount of pressure on the reg? Was thinking 97 Vette style rail mate to stock return feed lines, 60# mototrons, and maybe an adjustable regulator (found one that fits stock rail looks like) with vacuum ref regulator. 60#s idle good in stock returnless setup with vacuum line on it at idle out to idle like a dream at say 50 psi, and on full tilt at 65-75 psi the Motos have fed mid 800 rwhp
Mike
Mike
