How much nitrous?
Old Apr 19, 2005 | 11:10 AM
01SSDRVR's Avatar
Default How much nitrous?
Im planning on getting a nitrous kit for my car. My question is how big can I go with my setup. I have a crane 230/232 @600" 110* LSA, Long tube headers, true duals, 4.10's and boltons. Everything else is stock and I havent had it tuned yet. Should I wait till I get the nitrous to tune it and how much can I spray before I blow something up? Also should I get a dry or wet kit? I am a nitrous newb.
Old Apr 19, 2005 | 11:48 AM
slow trap's Avatar
i'd wait to get tuned untill you have the n20 up and running.a fuel pump might be a good idea before you get tuned also.those 4.10s will make you have to shift very quickly on the jug also.
Old Apr 19, 2005 | 12:50 PM
01SSDRVR's Avatar
I wasnt sure if I needed to tune it with the nos or not. also I dont plan on using the nitrous until I was off the line.
Old Apr 19, 2005 | 02:30 PM
Ole1830's Avatar
If you're going to stay on the small end of shots (<=100 shot) then there's nothing inherently wrong with a dry shot.
Most people end up getting addicted to the hit and end up going with a wet shot so they can spray bigger.
If you're spraying a dry shot, then typically 28lb injectors will handle up to ~425rwhp. Then your injectors will run out of capacity to deliver fuel. So if your car is putting down 375 to the wheels NA, then you can typically add a 50 shot with relative safety.
A fuel pump is something you'll want to invest in, regardless of whether you're spraying wet or dry, if you're putting down any more than 450ish rwhp.
A wet kit is typically easier to tune AF ratios, can handle bigger shots more reliably, but requires a few extra things to work properly.
A dry kit is typically cheaper, simpler, and easier to hide. It's typically also harder to shoot a bigger shot with them, because you need to upgrade the injectors if you get big on the power.
Matt
Old Apr 19, 2005 | 03:35 PM
01SSDRVR's Avatar
Matt
ok im hoping for at least 400 hp to the wheels with out the nitrous, so basicly i have to upgrade the injectors and the fuel pump before I sould even consider running nitrous? how much can the bottom end handle before it goes boom? also what size injectors did the 01 camaros come with?
Old Apr 19, 2005 | 08:16 PM
Ole1830's Avatar
Most people just upgrade the fuel pump and spray wet with a H/C car, but I like my dry kit, because it's what was on the car and it's simple.
I also never intend to spray more than 75/100 with heads and cam. I also had the tuner rework my fuel mapping for the 36# SVO fuel injectors when I did my heads and cam.
I believe the '01 and '02s came with the 28lbers. You'll know how much you can spray safely when you get it dynotuned.
I wouldn't spray it until you get it tuned. There's really no way of knowing for sure if you're getting enough fuel without a dynotune with wideband AF.
Matt
