Nitrous outlets dedicated fuel system.
Old May 13, 2005 | 02:26 PM
Nitro Dave's Nitrous Outlet's Avatar
Aries.
Not a problem.What we do in cases like yours is simple.Instead of building the cell with the hold down flang on the bottom we take and build it with and are for bolting it down.
Dave
Old Aug 4, 2005 | 07:11 PM
Sandmann120's Avatar
Any news yet on the other cell?
Old Aug 5, 2005 | 08:58 AM
Yes sir we have finished all three desighns.
Dave
Old Aug 5, 2005 | 10:04 AM
Z284U2TRY's Avatar
How much is the smaller front mount cell going for?
Old Aug 5, 2005 | 11:16 AM
The system that does not require relocating the battery come complete for 699.00.
Here is a link to the system.
http://www.nitrousoutlet.com/outlet/...section_id=122
Dave
Old Aug 8, 2005 | 05:12 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Dave-
I sure would like to see some installed pics of the version that does not go in place of battery - I can't figure where you have room to place that anywhere by the fuse boxes?
Old Aug 8, 2005 | 07:51 AM
JoeyGC5's Avatar
Nitro Dave, going froma calculated guess. How long would the C5 kit last before needing a refill on a 100hp TNT kit shot? Is there a possiblitiy of prox or fuel level indicator?
Old Aug 8, 2005 | 10:20 AM
Joey,
The tank is larger than a gallon and weighs in at 6.75 lbs. You only 1/2 lbs. per hour per horse power.So for a 100 shot you only need 50lbs of fuel if you were going to have it on for an hour. But since you are only on for 15 or less, 50 / 60 /60 x 15sec. = .208 lbs of fuel.. So he could make 30 passes and have some left.
Im horrible at figuring stuff like this up so I had it done for me.I hope this helps.
Dave
Old Aug 8, 2005 | 10:31 AM
JoeyGC5's Avatar
Thank you sir
Old Aug 8, 2005 | 10:46 AM
Bad Habit Bird's Avatar
I can't tell from the pics does it have a return line? If not have you had any issues with it not having one?
Old Aug 8, 2005 | 01:34 PM
Sean,
The regulator is a return style, and it uses a special fitting that connects it to the bottom of the tank. This makes the install very compact and clean.
Dave
Old Aug 8, 2005 | 01:54 PM
  #32
Very Nice!!!
Old Aug 15, 2005 | 04:19 PM
  #33
Thank you.Now we need to put one in that camaro you just picked up.
Dave
